No IPLAYER on UK WDTV Live Streaming
I bought my WD SMP yesterday, loaded it up - no iPlayer.
Newest firmware 1.12.14
There is a possibility that WD have discovered the problem. I’m therefore hopeful that they may rectify it quite soon.
When I spoke to WD today - the guy said WD are aware of the problem and will fix it soon - maybe via a software update.
In theory they just need to fix their server.
OK WD have sorted out the problem. If you go to setup / system / set time & country / reset location and select yes, you should find all the UK services back. If you have any problems do a reset to factory defaults and report back here.
Hurrah, will try this when I get home and report back.
Done it mine is sweet iplayer ad aetrax all good
iplayer working now - well done WD!
Thanks to the OP and all you guys that helped.
