Hello, i have a problem with my raid 5.
Problem started when i tried to put my computer to sleep. It turned off, then on again and then in bios window it shows status “Rebuild” but all drives are green. Imgur: The magic of the Internet
BUt when i look in intel’s Rapid storage app it shows problem with one of my drives. Imgur: The magic of the Internet
What i should do at this point ?
Ive already tried WD disc utility tool and tested. Raid passed the test
Hello salemas5,
You should try contacting WD’s Technical Support about this for live assistance and troubleshooting.
The link below will allow you to call support
I’ve posted same post on intel’s support forums too and they helped me to fix my issue.
https://communities.intel.com/message/517653#517653
