I have 2 external drives connected. One 2TB and one 1TB drive.
When you select to “Sync from external drive” you are limiting yourself, since you cannot sync 2 TB of content from the external drive onto the miniscule 1TB drive in the HUB. So I’d turn that off if I was you. Leaving you with (almost) 3 TB of storage combined.
the external drive should be seen on its own and shared by the Hub on the net, and you include it in the catalog search by setting the source to All Local Storage.
Photon_Boy… The selection for source (set it to All Local Storage) is local to the data type. (Photo, Video).
If you have to select it every time you go to Video, you should try going to Video and setting the datasource to 'All Local Storage" there. Then all will be combined into the catalog.
I have the WDTVHub Syncing to a folder on my Netgear ReadyNAS 600 Ultra Plus, working fine.
My question is, I just added a Seagate 2Tb Desktop USB Drive, the 1Tb drive in the hub is full. If I move movies over to the Seagate to free up space, will the WDTVHub pull the movies I just moved from the network sync again?
