WD Mypassport ssd wifi 4TB Upgrade
Hi Danny, sorry for the late reply, I’m not home most of the time.
The BMS should be like ~5cm in length, ~0.8cm in width and ~0.1cm in depth (with all the cables and solder material), if I didn’t make no mistake :stuck_out_tongue:
See the attached pictures;
Please let me know, how it went for you, I’m eagerly interested :slightly_smiling_face:
Thanks and no worries. I was able to measure the size without breaking open the wrap around the battery (didn’t get the depth but that should be okay).
The upgrade went well, I only needed to flash the firmware once. The drive originally reported it was only 256GB but a “System and Disk” "factory restore fixed that and it now reports the correct volume of 4TB. I also managed to find another Wireless Pro that was relatively inexpensive so now I have a backup for parts or the option to make another My Passport Wireless SSD!
YES! That is perfect. Believe me, I’m happy it worked :grin: In a sense, you’ve paved the way for others, when they see your success.
And in addition you’re now a proud Red owner :smile:
The BMS should be approx. 1mm in depth, probably better, if you can cut/print out 2mm, though, for the cables to be soldered and such. Knowing the battery pack comes from WD, it’ll probably fall, sooner, or later :roll_eyes:
So I was testing the drive today by backing up SD cards. After a few cards (~300GB) the drive shut down because it was over safe temperatures. I let it cool down for 30 minutes and when I tried to turn it on again it wouldn’t boot, all the LEDs started flashing indicating there was a file system error. I tried plugging in the drive and it wouldn’t mount. I put the SSD on another SATA board and it mounts. I tried to flash the firmware again and that doesn’t work. I put the original HDD back into the board and that also mounts when plugged in and boots normally when it’s not plugged in. I tried both boards I have and the same thing happens… Going to return this drive. I’m just not sure if I should order a new one and try again…
P.S. I already ordered the battery sleds.
Mhm, that is curious indeed. If you order another drive, let me know, how it goes. I mainly use mine as a mobile Plex server and, of course, storage of media files and hadn’t had any problems.
Greetings!
I plan to install WD Red SA500 WDS400T1R0A in my WD My Passport Wireless Pro following steps from https://www.youtube.com/watch?v=NrpMVvgIUEw.
How much space should I allocate for the exFAT firmware partition?
What is the minimum and optimal size of the partition in MB?
Thank you.
Set aside 4GB for the firmware partition
I ain’t sure, if that’s really important. I can’t seem to recall the details of me going through the procedure :stuck_out_tongue_closed_eyes: but in the end you can reset and even reformat the drive, once the firmware’s on.
I confirm successful upgrade of WD My Passport Wireless Pro to WD My Passport Wireless SSD by replacing the original 1 TB HDD by a 4 TB SSD WD Red SA500 WDS400T2R0A-68CKB0:
The drive can be inserted out of the box without prior initialization. Firmware installation followed by Restore Factory Default Settings | System and Disk will automatically prepare the following drive layout:
I hope this will help enthusiasts to make the most use of WD My Passport Wireless Pro/SSD.
Thx very much for this info!
Which firmware did you use?
And how did you installed it, with browser menu or with the sd card method?
see bottom right corner of the screenshot above
I used SD card method, since the SSD was not initialized after insertion to SATA slot of the device.
My man! :wink::smile:
