WDTV HUB questions
i just setup my hub lastnight and connected a 1.5tb external hdd to it that contained my media files, question is do i have to sync and copy those files over to the main hdd to be able to use and share them with another WDTV live device or play them on the hub?I’d like to be able to use both hdd’s at the same time if possible.
You should be able to see the content on the Hub and drives connected to it via any DNLA device on your network.
anyway i can disable the popup that asks me to sync the drives?so it doesnt want to to xfer the files from the usb hdd to the main hdd
Yes, you can. Turn off that request in settings.
