How to Sync 2 WD My Cloud 4TB drives on two remote networks
I want to sync two WD My Cloud 4TB drives at two different locations
…|___Firewall
WD My Cloud 4TB A -----Switch---- Computer 1
… |______Computer 2
…|______Computer 3, etc.
At a different location
WD My Cloud 4TB B ----Switch---- Computer B
I am backing up Computers 1,2,3, etc onto the My Cloud A. I backup Computer B to WD My Cloud B.
I would like to sync the My Cloud A to the My Cloud B so I have an offsite backup for each drive
Can this be accomplished using WD My Sync Software, or must I use a windows version of rsync like DeltaCopy?
If I must use DeltaCopy, how do I allow penetration into a remote network with a static IP protected by a SonicWall Firewall device? I’m assuming if I run the sync from the location with the dynamic IP address, this will not create a problem.
See my reply to the same question you posted in another thread:
http://wdstagingsplit.staged-by-discourse.com/t/unable-to-create-a-backup-from-one-my-cloud-gen2-to-another-identical-my-cloud/150820/6
