ix400
July 30, 2011, 2:19pm
1
Hi!
I just receiverd my brand new Live Hub! Loooks good, very beautiful UI !
But: I set the HDMI output to auto, but when I play a 24p file from the file menu it doesn’t switch automatically to 24p.
I thought the unit would automatically adjust the proper frame rate on the HDMI port, like 24p, 50i, 50p ?
I was pretty sure that the new live hub can do this native framerate output thing. Did I get this wrong?
I’m a bit frustrated.
Chris
Did you set the Framerate Matching to ON?
ix400
July 30, 2011, 2:37pm
3
I set HDMI to “auto”. Is there an additional setting I might have overlooked?
Thanks for your fast reply,
Chris
Scandy
July 30, 2011, 2:44pm
4
‘Auto’ means that the WD box will automatically find the best resolution/frequency to sync with your TV. As Tony said, you need to turn on Framerate Matching to do what you want.
ix400
July 30, 2011, 2:49pm
5
… okay, but where can I find this setting? I’m running the latest firmware (2.06…).
And the manual also doesn’t know the framerate matching…
Chris
After you select AUTO, it will ask if you want to enable Framerate Matching.
ix400
July 30, 2011, 4:10pm
7
Thank you sooo much! That’s it!!
I’m gettin’ old.
Chris
:smileyvery-happy:
