A few tips please
hi there
Following instructions from here:
transmission installation fails with an error
Setting up transmission-daemon (2.84-0.2) …
[…] Starting bittorrent daemon: transmission-daemon/usr/bin/transmission-daem
failed!
invoke-rc.d: initscript transmission-daemon, action “start” failed.
dpkg: error processing package transmission-daemon (–configure):
subprocess installed post-installation script returned error exit status 127
retried installing and
ELF load command alignment not page-aligned
failed!
E: Sub-process /usr/bin/dpkg returned an error code (1)
Now i don’t know all that much about linux.
i know that drives need to be mounted to be used.,
I have two disks attached to the usb port of wdMycloud
Is there some sort of graphical interface for tranmission that lets me choose drives, where to “pickup” said torrent file or magnet file and then choose where to save finished download?
Ideally i would download everything via wdmycloud and have it tranfer files atumatically too… is this possible?
Thank you in advance
Hi arythion,
You should try contacting WD’s Technical Support about this for live assistance and troubleshooting
The link below will allow you to call support
Create a Support Case
Create a support case with our world-class service and support team.
