I am running two My Cloud Home devices and enabled the Plex server on each.
It’s my understanding that this creates two different servers that run independently of each other. That is fine. I’ve read this support article on the Western Digital My Cloud Home Drive Western Digital My Cloud Home | Plex Support
However, the problem I am having is that on one of the drives/servers I am able to “add folder” when adding a library and on the other drive the option doesn’t even show up.
I understand there are the pre-populated Plex folders that get made in the drive when enabling the Plex server. But for the one drive/server I wanted to create a custom library of concert videos I have. I was able to do so on the one drive. The option shows up.
The support article says that this isn’t possible with a My Cloud Home drive, but I was able to get it to work with the one. So, it must be possible now?
The help I need is how to get it to work on the other drive/server.
Upon further looking, the Plex Media Servers on each of the drives are different versions…
The one that IT WORKS on is
Plex Server Version 1.25.9.5752-344846934
Software Version 8.9.0-108
The one IT DOESNT work is
Plex Server Version 1.18.6.2350
Software Version 7.16.0-220
I’m guessing these different versions could be the culprit? I know it says there is no way to force an update. With that being said, how do they get updated?
Hope this all makes sense. I found a reddit article with someone that had the same problem… https://www.reddit.com/r/PleX/comments/ub3uiv/add_folders_option_not_showing_in_my_plex/
I’m obviously having the same issue, but since I can add folders on one of them and the other I cannot, it seems like there is more to the issue here.
Thanks in advance for any help!
