I have the same issue as this poster (different drive) and would like to know the answer to the first 3 questions.
Basically: Can I return the advanced RMA replacement drive?
If I can, do I still get to retain the full (5 year) warranty on my original drive?
(I opened the anti-static packaging and ran some tests and grabbed smart data off of it but have not written to it or cloned my old drive).
THIS IS MY ORIGINAL DRIVE:
smartctl 6.0 2012-10-10 r3643 [i686-linux-3.7.5-pmagic] (local build)
Copyright (C) 2002-12, Bruce Allen, Christian Franke,
=== START OF INFORMATION SECTION ===
Model Family: Western Digital RE4 Serial ATA
Device Model: WDC WD1003FBYX-01Y7B1
Serial Number: WD-WCAW3517****
LU WWN Device Id: 5 0014ee 2b2ab626d
Firmware Version: 01.01V02
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 3.0, 3.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sun Jun 9 13:39:58 2013 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 16
3 Spin_Up_Time 0x0027 179 170 021 Pre-fail Always - 4050
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 124
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 1136
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 121
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 11
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 112
194 Temperature_Celsius 0x0022 113 097 000 Old_age Always - 34
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 1
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
____________________________________________________________________
The Pending Sector Count rose to around 40 at one point in time, but is now sitting at 1 (I ran checkdisk twice and it repaired some things, I found files that had been “rescued” by it later and replaced them).
This all started one day when I turned on my computer and logged into windows, shortly after everything became sluggish, then stopped responding, I tried to bring up the security options dialog (ctrl+alt+delete) and got the message “Log on process has failed to create the security options dialog” and a mostly black screen. Let it sit for some minutes but no change so forced the machine to power-off by pressing and holding the power button.
(I should note that my drive is somewhat noisy, always has been and I understand this to be typical of the series, but during the above period it was quite loud, I understand this may be due to the heads moving rapidly over areas they’re having trouble reading for whatever reason.)
I started back up and checked various things, no real problem until I opened speedfan to glance at smart values and saw to my surprise red and a value for Current_Pending_Sector that was I believe around 10 at first. I checked back later and it had climbed to the teens. I restarted and booted into parted magic, the value was now in the 20s and I tried to run a short test but got read error with an LBA value. G-Parted also placed a flag indicating bad/pending sectors.
Long story short I tried to run tests but got nowhere. Put in an RMA (I had another drive [old and out of warranty] with similar problems and it deteriorated rapidly with lots of data loss so I didn’t feel like taking chances as I don’t currently have a spare drive I can use to backup). Did some more research (sadly not the easiest thing when everyone recommends zeroing as the only solution) and found that certain tools (HDAT2, MHDD) can force re-examination and/or reallocation of bad sectors without necessarily destroying data. Running these cleared up the pending count to where it now sits at 1 (I’ve been unable to find this last one so far but I’m going to go on another hunt).
The Raw_Read_Error_Rate has actually been present since I got the drive (well not day one) and gradually creeped up, but as it is still low and hasn’t climbed rapidly I was under the impression it isn’t a problem.
Presently I’m writing this from the system in question, I’ve been using it as normal and nothing has cropped up in the past several days.
Any opinions? Should I really go with the (older revision) replacement? I’d hate to send back an otherwise good (and up till now completely reliable) drive that I bought.
This is the first real trouble I’ve had with a WD product and I’ve been buying and recommending for some years now.
