After 40 second reset, I have not able to access the EX2Ultra except by logging in
After a 40 second reset, I went back to the basic WD instructions for mapping the EXUltra2, but I can no longer access the public share from either Windows 10 Pro or Home.
Interestingly, though my android can access the drive via a utility called CxFileExplorer.
Any suggestions would be welcome.
George
I went back and checked the following windows settings:
  1. Open the Local Group Policy Editor (gpedit.msc).
  2. In the console tree, select Computer Configuration > Administrative Templates > Network > Lanman Workstation .
  3. For the setting, right-click Enable insecure guest logons and select Edit .
  4. Select Enabled and select OK .
Then I started the WD instructions
How To Map a WD Network Drive on Windows 10
Map Drive by Device Name
This is what happens when I try the name in windows explorer
This is what happens when I try the IP address in windows explorer
I end up logging into the device instead of getting network Public share access
Here is network configuration on the EX2Ultra:
This is the result when I try that:
PROBLEM FIXED BY USING THE FOLLOWING:
If my memory is accurate, that was a name that windows seemed to come up with during browsing. This doesn’t make any sense since the list under the Network doesn’t show that name but the map with a hard IP address seems to be working, so that is what I went with.
I have no clue why mapping doesn’t work, since you can see the systems mounted on the PC:
Yes
Two thoughts,
First is did I fat finger the NAS name in my dozens and dozens of attempts to get this working or do I have a “kidnapped router”.
Secondly is that I have a “kidnapped router”.
All computers and phones are running Bitdefender “total security”.
I have a Verizon Actiontec M1424WR router running WPA2. I could further protect myself by preventing SSID broadcasting and use MAC authentication, but I thought this was overkill.
How can I further analyze my risks?
Interestingly enough, when I decided to add my wife’s machine, an MS Surface windows 10 pro, it did NOT require any credential authentication to become visible.
