Ditched linksheets just to use this, loving the dark colours and the speed. Just use the large cover view as I have seen 99% of my movie info by now anyway, and just like big pictures.
when i display the actors in gallery view, is it possible to set a maximum value of actors that are displayed? i dont want a name to get cut off in the middle
No, you can’t specify Maximum Values for Actors.
Just as you can’t specify Maximum Values for Movie / Tv Titles.
All you can do is specify the “Width” or use a “Scroller”
“Width” will cut off text
“Scroller” will scroll the text (but doesent work with “Actors”)
It may however work with the Latest Firmware which has “Actors” with a single tag now.
eg.
<cast>Gary Oldman / Cillian Murphy / Rutger Hauer / Mark Boone Junior / Christian Bale / Michael Caine / Liam Neeson / Katie Holmes / Ken Watanabe / Linus Roache / Richard Brake / Sara Stewart / Tim Booth / Rena Sofer / Tom Wilkinson / Alexandra Bastedo / Morgan Freeman / Jack Gleeson</cast>
BUT, the “Actors” would have to be a Single Line (Not a Mulit-Line Text)
I have a small problem with the main menu and I can’t see how to get it right. I have tryed all the themes from Alaska Revisited (dark and light) and all the themes have this small problem.
I wanted to fix it, but I can’t see to find the code I need to delete.
I think nobody noticed it because it is difficult to see, it’s not my intention to post a bug, but I am just curious how I can solve this.
When you play music, you can push the Home button on the remote and you will go to the home screen. On the bottom left you have a nice image of the cd you are listening to. But you also have the album name inside the menu icon that’s called now playing.
I have difficulties creating a screenshot, so I took the good old paint tool on my computer and I found an image from an older version of this theme. I marked in pink where the album title is displayed in white letters:
In this image you won’t see the white letters, but if I could create a good screenshot you can see it.
Does anyone have a clue how to get rid of this? I can adjust codes myself, but this is a difficult one. In other themes (like CoCo) it’s gone, so it should be somewhere in the xml codes?
I have what I guess is a question. I haven’t used Pandora on the WDTV Live SMP for a while but the last time I did I remember it being easy to jump to the next song. I just installed the latest firmware on the box and reinstalled Alaska Dark and everything is working great except I can’t seem to get Pandora to skip to the next song. Either I just don’t remember how to do it, which is a distinct possibility or something is not working right.
Can someone remind me how you skip to the next tune in Pandora on the WDTV Live SMP??
Thanks everyone. I am loving my box and I have absolutely no problems playing everything I throw at it.
I have tried it with dark and it still shows the standard background *on the main menu. Is there anything I can do other than just set the background in setup?
The Focused icon has a Hard coded background to blend in with the Home Menu background. Gives the illusion of Transparency.
“Changing the Backdrop in Setup” that’s the “Long Way Round” … i just go to Photos from the Main Menu press “Option” on my Picture and set as Background.
