This is a Non-Moviesheet Theme (ie. It’s just using Poster Thumbnails)
3rd Party Software (eg. “Thumbgen” is NOT Required) it’s optional if you wish to use it.
(Inspired by Xbmc Alaska by Hitcher)
<=========== CLICK THE "Kudos"STAR, If You Want To Say “THANKS” ![]()
NEW “DARK VERSION” (LIGHT VERSION BELOW… Scroll Down)
ALL VERSIONS DOWNLOAD PACKAGE (15MB)
(LATEST UPDATE 6th Feb 2015 … Fixed the “Play” button on remote control not responding)
http://www.mediafire.com/download/wg300sn9l32uabo/Alaska_All_PlayFixed.zip
Contents of the Package
AlaskaDARK_V1.3.zip (The 1st group of Screenshots on this Page)
AlaskaLIGHT_V1.7.zip (The 2nd group of Screenshots on this Page)
AlaskaLIGHT_V1.7_15_TBN_VERT.zip (15 Thumbnails Vertical Poster)
AlaskaLIGHT_V1.7_15_TBN.zip (15 Thumbnails Landscape Cropped Poster)
_______________________________________________________________________
Dark 15 Thumbs Version Update: 11th Feb 2015
(fixed Play button not working and added Music Playback screen for new WDTV and 2.02.32 SMP)
Single ZIP file contains:
AlaskaDARK_V1.3_15_TBN_VERT.zip
AlaskaDARK_V1.3_15_TBN.zip
AlaskaDARK_V1.3_WATCHED2.zip
http://www.mediafire.com/download/b30n1f6czcp6by6/3_DARK_PLAYFIXED.zip
5th March 2014: Requests for the “Watched” icon added to views
These are the Home Icons Template i designed … they are not PSD(Photoshop) nor XCF(Gimp) but where desigined using TViXie Designer then Used Thumbgens “Quicksheet” option to generate PNG’s which were then canvas resized and scaled using Gimp.
Sorry, i’m not a Photoshop or Gimp “Whiz”
http://www.mediafire.com/?w94cijfi2i9rb82
____________________________________________________________________________________
This was designed and Tested on Firmware 3.05.10 by myself and other ‘testers’
It will work with Firmware 2.07.17 (Except Preview Browse Info … Which will out of alignment)
This Theme was tested working with Media Library On and Off.
A README TEXT:
* The Theme is a Non-Moviesheet Theme … it only uses “Poster” Thumbnails either generated via the Hub’s Internal Meta Scraper or a 3rd Party
Scraper… eg.Thumbgen
So, if you “Are” satisfied with the Jpeg Picture Quality of the Hub’s Scraped Posters … then you dont need to use a 3rd Party Application.
If you are “Not” satisfied with the Jpeg Picture Quality then of course, you can use a 3rd Party Application to generate Poster Thumbnails.
It is Recommended to use and not to exceed a Resolution of 300(w) x 450(h) Dimensions.
Whilst the Theme will do the best to Scale / Align / Fixratio of the Poster Thumbnails it is Recommended to use Posters with and Aspect Ratio of 2:3 or a Scaled Down Resolution of 1000x1500 which is a Popular Standard Format of the TMDB.
Dont use 1000x1500 !
use a “Scaled” Resolution … eg. 300x450, 200x300, 178x267, 120x180 are examples of scaled and maintained
Aspect Ratio based on 1000x1500.
________________________________________________________________________________________
* The “Appearance” of a Landscape “Fanart” image (eg. Gallery View on the Left Side of Screen) is a Vertically Pannned and Top Aligned Image of the Poster
Thumbnail Image.
For Movie/Tv Posters with the Graphic Art Focused at the “Top” and the Title/Text is Vertically Bottom Aligned… this “Simulated” Fanart effect is suitable.
For Movie/Tv Posters with the Graphic Art Focused at the “Bottom” and the Title/Text is Vertically Top Aligned… then does not look so good.
2 Workarounds… Find an Alternate Poster that is Suitable or Custom Design one.
__________________________________________________________________________________________________
* The Theme will work with the Media Library ON or OFF …BUT disabling the Media Library will Disable Features / Views and Picture Quality.
* The Option for “View Backdrop Photos” is only Available if you have gathered the Movie Info via the Hub’s Internal Scraper and you have the Media Library ON.
Also, the “View Backdrop Photos” Option … i modified it soley for use in “Gallery View” . The Internal Firmware does Not display a Movie Plot / Overview
whilst in this mode.
I modified it to be an “Overlay” on top the Gallery View.
Using the “View Backdrop Photos” Option in any other View is not Recommended.
How to install a Theme {Guide}
To install the theme, download the zip file to your PC, open your web browser (I don’t recommend using IE8 or IE9, there have been issues), then type your WDTV’s IP address to open the Web UI.
(Find your WDTV’s IP from Setup > About )
Type in your password (the default is “admin”), click on the box next to “I accept” and then click on LOGIN, then click on “Appearance”, then click on “Browse” and navigate to where you saved the “AlaskaDARK_V1.2.zip” file, then click on “Open”.
Click on “Submit”, then once the Web UI finishes uploading the theme (which will take approx 30 secs), on you WDTV press “Setup” on your remote, select “Appearance”, then select “User Interface Themes”, select “AlaskaDARK_V1.2” then when prompted select “Apply theme”.
