This is PsychoTHC’s Anodized Theme with my Trickle modifications. This is a beta version, the Original release will be in my theme that I’m working on, but since it’s not close to being ready yet, I’ve imbedded my mods in PsychoTHC’s theme for now.
READ ME BEFORE USING.
To use this theme with with the Trickle and reflections you will need to make your icons a certain size for it to display correctly. Folder icons can’t be used with reflections, due to a limitation in the firmware, but need to be 185 X 278 for them to display correctly (although larger icons should also display correctly as long as you keep the same ratio).
For the Cover art to display correctly, they need to be 185 X 349 (this is actually having the icon as 185 X 278 without the reflection and 185 X 349 with the reflection, if that make any sense). You could use larger icons with the same ratio, but you will probably get overscanning with the larger (poster) icon.
To make your Coverart with reflections, I have already included Thumbgen Cover box templates with this Theme which will output the Coverart icons the correct size to work with this theme. Just copy them to your Thumbgen template folder. To get the reflections to work, you have to use the same method used to create transparent Moviesheets.
Set Thumbgen to output the Coverboxes as png’s, then manually change the extension to jpg.
Also, I have included a Trickle test folder, you can copy this to your HUBs internal dirve, then see how the reflections work. Select the Test4 Folder, which is the only folder that contains movie coverart, to see how the reflections look. Once you decide that you want to use it with the reflections, you can start making your new coverart icons using Thumbgen, but I would backup your original icons, so that if things should change and you need them, you don’t have get them again, you can just copy and replace the one’s you have made with the reflections.
So without any further adieu, here it is:
Hope you enjoy! ![]()
