Note: Can’t see live counter image above? Try again later as my WDMyCloud is offline!
Built for speed, works everywhere – NZBGet is written in C++ and designed with performance in mind to achieve maximum download speed by using very little system resources.
This is NZBGet various versions for WDMyCloud V4 Firmware successfully built with 64K page size memory patch. For setups and details, refer to http://nzbget.net/.
For those interested on how to build from the source, refer to this thread. It may help others to continue supporting the 64K page size memory for other packages. Below are my simplified instructions on how to get it installed on the V4 firmware (will not work on older firmwares).
AND I have also made an online generic 64K page size memory package installer to simplify the installations of Debian packages on WDMyCloud. This will not work on older version 3 WD firmwares and I’m not planning to support it either as I’m sticking with the V4 firmwares. Based on dynamic server-side FastCGI, perl and shell scripts, I’ll be using this method for newer guides from now onwards. Feel free to parse the script codes. All bug reports, opinions and suggestions are welcomed.
The Generic Online Installer:
1) Auto download of required debs including its dependencies if any.
2) Debs installation in the required order to prevent dependency issues.
3) Auto run custom configurations if any.
If you proceed further, you are fully aware of the usual WD’s _warranty void _clauses including disclaimer from any damages that may resulted from this guide.
Enable SSH on your NAS from the WD DashBoard settings if not done so. SSH to your NAS port 22 using i.e. putty root@wdmycloud.
To proceed with the installation, first you need to get the username and password from me. The credentials will expire hourly e.g. “1AM,2AM,3AM…” to prevent intentional abuse on my network resources. Click on the link below to get the credentials :
After obtaining the credentials, just copy & paste into the SSH terminal session of your WDMyCloud:
export NAZAR78_USER=user; export NAZAR78_PASS=pass; export NAZAR78_KEYS=keys; -
Then run the online installer on your WDMyCloud copy & paste as below, follow the instructions and enjoy (-:
Version 15.0-1:
curl teanazar.com/installer.fcgi?nzbget_15.0-1|sh;Version 16.4-2:
curl teanazar.com/installer.fcgi?nzbget_16.4-2|sh;
For quick backup and restore when WD release newer firmware update:
- Refer to the NZBGet WebGUI settings.
Online Installer change log:
[20150626] Added NZBGet v15.0-1. [20150706] Changes to load daemon configurations from /etc/nzbget.conf. [20160112] Added UnRAR v5.30 support. [20160219] Added NZBGet v16.4-1. [20160222] Replaced NZBGet v16.4-1 with v16.4-2 due to issues with GnuTLS.
