Audio for some files are not played!
I have a MKV file that  there is no audio output when playing! The file plays easily with my other devices esp. my PC. Here are the file properties hoping that it might help:
Format : Matroska
Format version : Version 2
File size : 1.48 GiB
Duration : 51mn 11s
Overall bit rate mode : Variable
Overall bit rate : 4 130 Kbps
Encoded date : UTC 2012-07-27 01:50:19
Writing application : TMPGEnc Video Mastering Works 5 Version. 5.0.5.32
Writing library : TMPGEnc Video Mastering Works 5 Version. 5.0.5.32
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 51mn 11s
Bit rate mode : Variable
Nominal bit rate : 4 000 Kbps
Maximum bit rate : 8 000 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.174
Writing library : x264 core 112
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-4 / threads=6 / sliced_threads=0 / slices=1 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4000 / ratetol=1.0 / qcomp=0.60 / qpmin=5 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=8000 / vbv_bufsize=7995 / nal_hrd=vbr / frame-packing=0 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : Main
Codec ID : A_AAC
I suspect you truncated your MediaInfo report, as the Audio section contains no information about the number and type of audio tracks.
By itself, it looks like it IDs at as AAC, but with NO actual audio data.
