My Note 5 won’t auto backup all my photos. For example when I take 5 photos in a row then open up my WD cloud app while within WiFi range of my My Cloud device it starts to backup but only chooses to backup 1 or 2 of the photos I just took. It doesn’t ever backup the other photos. Is there a setting that I am missing or need to change? What does the cache setting do? Also I have to open up the WD my cloud app for the auto backup to start. Is this normal?
I recommend you uninstall and reinstall the app on your phone.
What app version are you using? What have you chosen in Back up options?
cat0w
USA
That seemed to do it. Thanks.
