Best HDD for Video Streaming over LAN
Hi All,
I need to change my desktop HDD , I will need it to store all my documents and audio/video files , than all media files will be played on a WD tv live (over lan).
Disk will remain up all the day…
Which cuold be the best? I’m looking for a WD Red 2tb , It cuold be ok or there’s something best (or cheapest) ?
Luca
Hello, welcome to the community.
If you are looking to install the hard drive on a computer as you mentioned the WD Red are the way to go, however I would recommend a NAS like a WD My Cloud or WD EX2100, as this hard drives have dedicated media server and can be accessed over the network without the need for a leave the computer on.
Hello lluna,
Thanks , I know that a NAS would be the best solution, but I have to change both my desktop disk (I will buy one SSD and the WD Red as storage disk) and for now I need to follow the cheapest way.
In the future, if possible, I will buy a NAS , but for now desktop and an wxternal WD elements is the only way :frowning:
Thanks again
Luca
Hi, to give you an idea, my ex-gaiming computer has a SSD and 2 WD Red’s on RAID 0, and I now use them to stream movies from my desktop to the WD TV Live I have connected to the big screen. I have to add that I do not leave his PC on 24/7.
It’s somthing like my situation.
I’m waiting for a new SSD , I will buy also a WD Red 2tb where I will store all my file that I will stream on WD Tv on main tv.
When I will have some other money I will buy a NAS to store and stream all the files :slight_smile:
Luca
