Blinking green light
hi all,
why is the green light always blinking? my MBL is not in used, i do not run backups, no access. why does it not stop blinking?
also, in settings, remote access, i can’t see a thing. why are the settings not displaying?
frankly, so far i’m very disapointed with this product.
please help!
Hello, try to update the firmware to the latest  version, if that doesn’t work, press the reset button for 4 seconds.
If remote access is enabled, and also the Twonky and iTunes Server, this may cause the MBL to be always active.
