I have read many pages on the Blu ray to MKV subject and spent a few days converting files and to no avail. I can play them on my computer but not on my WD TV Live Plus. I use AnyDVD HD to rip the Blu ray to my HD. Then I use Handbrake to encode it making sure to use the Regular: High Profile preset. I next Go to the video tab and choose MKV file under the container. Finally under audio I pick the AC3 passthru. I can not play any of the files with my WD TV Live Plus. Does anyone have any idea what it could be. Any help would be greatly appreciated.
If you don’t have it already, download and install MediaInfo from here. Run and then post the results. Must be an issue with how you’re creating the MKVs.
I stream full uncompressed BR main movies from my NAS to my WDTVLive + and they play great.
Here are the results after a fresh Blu ray conversion
General
Count : 277
Count of stream of this kind : 1
Kind of stream : General
Stream identifier : 0
Inform : Matroska: 746 MiB, 21mn 27s
Unique ID : 150078088427099613366168320159047072763
Unique ID : 150078088427099613366168320159047072763 (0x70E7FD0B0C0BB63C88B22C6099A1BBFB)
Count of video streams : 1
Count of audio streams : 1
Video_Format_List : AVC
Video_Format_WithHint_List : AVC
Codecs Video : AVC
Video_Language_List : English
Audio_Format_List : AC-3
Audio_Format_WithHint_List : AC-3
Audio codecs : AC3
Complete name : C:\Final Projects\Justice League.mkv
Folder name : C:\Final Projects
File name : Justice League
File extension : mkv
Format : Matroska
Format : Matroska
Format/Url : http://packs.matroska.org/
Format/Extensions usually used : mkv mka mks
Commercial name : Matroska
Codec : Matroska
Codec : Matroska
Codec/Url : http://packs.matroska.org/
Codec/Extensions usually used : mkv mka mks
File size : 781813565
File size : 746 MiB
File size : 746 MiB
File size : 746 MiB
File size : 746 MiB
File size : 745.6 MiB
Duration : 1287661
Duration : 21mn 27s
Duration : 21mn 27s 661ms
Duration : 21mn 27s
Duration : 00:21:27.661
Overall bit rate : 4857263
Overall bit rate : 4 857 Kbps
Stream size : 15557107
Stream size : 14.8 MiB (2%)
Stream size : 15 MiB
Stream size : 14.84 MiB
Proportion of this stream : 0.01990
File creation date : UTC 2011-05-11 05:11:49.707
File creation date (local) : 2011-05-10 22:11:49.707
File last modification date : UTC 2011-05-11 05:53:29.280
File last modification date (loc : 2011-05-10 22:53:29.280
Writing application : HandBrake 0.9.5
Writing library : libmkv 0.6.4.1
Video
Count : 196
Kind of stream : Video
Inform : English, 4 121 Kbps, 1920*1440 (4:3), at 23.976 fps, AVC (High@L5.0) (CABAC / 4 Ref Frames)
Unique ID : 950759622
Format : AVC
Format/Info : Advanced Video Codec
Format/Url : http://developers.videolan.org/x264.html
Commercial name : AVC
Format profile : High@L5.0
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 4
Format settings, ReFrames : 4 frames
Format settings, GOP : M=1, N=51
Internet media type : video/H264
Codec ID : V_MPEG4/ISO/AVC
Codec ID/Url : http://ffdshow-tryout.sourceforge.net/
Codec : V_MPEG4/ISO/AVC
Codec : AVC
Codec/Family : AVC
Codec/Info : Advanced Video Codec
Codec/Url : http://ffdshow-tryout.sourceforge.net/
Codec profile : High@L5.0
Codec settings : CABAC / 4 Ref Frames
Codec settings, CABAC : Yes
Codec_Settings_RefFrames : 4
Duration : 1287663
Duration : 21mn 27s
Duration : 21mn 27s 663ms
Duration : 21mn 27s
Duration : 00:21:27.663
Bit rate : 4120603
Bit rate : 4 121 Kbps
Width : 1920
Width : 1 920 pixels
Height : 1440
Height : 1 440 pixels
Pixel aspect ratio : 1.000
Display aspect ratio : 1.333
Display aspect ratio : 4:3
Frame rate mode : VFR
Frame rate mode : Variable
Frame rate : 23.976
Frame rate : 23.976 fps
Frame count : 30873
Resolution : 8
Resolution : 8 bits
Colorimetry : 4:2:0
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8
Bit depth : 8 bits
Scan type : Progressive
Interlacement : PPF
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.062
Delay : 0
Delay : 00:00:00.000
Delay, origin : Container
Stream size : 663243578
Stream size : 633 MiB (85%)
Stream size : 632.5 MiB
This is probably the screen you wanted to see its alot smaller than the one I posted a few minutes ago.
General
UniqueID/String : 150078088427099613366168320159047072763 (0x70E7FD0B0C0BB63C88B22C6099A1BBFB)
CompleteName : C:\Final Projects\Justice League.mkv
Format : Matroska
FileSize/String : 746 MiB
Duration/String : 21mn 27s
OverallBitRate/String : 4 857 Kbps
Encoded_Application : HandBrake 0.9.5
Encoded_Library/String : libmkv 0.6.4.1
Video
ID/String : 1
Format : AVC
Format_Profile : High@L5.0
Format_Settings_CABAC/String : Yes
Format_Settings_RefFrames/String : 4 frames
Format_Settings_GOP : M=1, N=51
CodecID : V_MPEG4/ISO/AVC
BitRate/String : 4 121 Kbps
Width/String : 1 920 pixels
Height/String : 1 440 pixels
DisplayAspectRatio/String : 4:3
FrameRate_Mode/String : Variable
FrameRate/String : 23.976 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Progressive
Bits-(Pixel*Frame) : 0.062
StreamSize/String : 633 MiB (85%)
Encoded_Library/String : x264 core 112
Encoded_Library_Settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language/String : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
ID/String : 2
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
CodecID : A_AC3
BitRate_Mode/String : Constant
BitRate/String : 640 Kbps
Channel(s)/String : 6 channels
ChannelPositions : Front: L C R, Side: L R, LFE
SamplingRate/String : 48.0 KHz
BitDepth/String : 16 bits
Compression_Mode/String : Lossy
StreamSize/String : 98.2 MiB (13%)
The WDTV only supports MPEG-4.10 (H.264) MP@L4.1 and HP@L4.1… it doesn’t support HP@L5.0
Handbrake 0.9.4, or any of it’s nightlies didn’t use L5.0 for the “High Profile” preset. They must have changed this for 0.9.5.
I guess we’ll have to change our advice. ![]()
I just finished ripping another copy of the same episode but the only thing i changed was the container and left it as MP4 File and it plays stright to the WD TV Live + just fine.
Well, I just downloaded 0.9.5… when I tried a DVD with “High Profile” I get HP@L3.0. When I tried A BluRay 1920x1080 with “High Profile” I get HP@L4.0, like I always did.
You perhaps changed some other setting that pushed it into L5.0? Because I can’t seem to get Handbrake to make L5.0 files by using the stock settings for the “High Profile”.
Is it possible that I somehow saved the profile so that when it loads I get the new “modified” profile? Still very new to using Handbrake.
Ok, I just woke up and I can see why it went to L5.0… your height is greater than 1080.
it needs to stay with 1920x1080p24, 1920x1080i30, or 1280x720p60.
Ok thanks for the info i will try a rerip when I get home from work and let you know how it came out. Thanks for all the help!
You guys are quick. I was going to look at the video profile as a potential culprit - good work RG. Another interesting note, and I don’t know how it will change after you change the profile from 5.1 to 4.1, but the aspect ratio looks odd. BR in 4:3? Not sure why they’re not 16:9 other than the fact that your “height” is 1440 - which would make for 4:3 ratio (1920/1440).
One last note, I’ve never seen a mediainfo listing with so much “■■■■” in the header. Mine are much cleaner and don’t have anywhere near as much superfluous information and advertisements. Don’t know if that’s bothering the WD.
Anyway, looks like you’re on the right path.
I believe the profile bumped up to L5 instead of L4, as soon as the height passed 1080.
That would be from the “Picture” settings on the first tab.
If the BR has it stored anmorphic, the actual 4:3 “display size” should be 1440x1080 instead of 1920x1440.
My 4:3 DVD’s end up with a “Display Size” of 640x480 if I choose strict anamorphic (which is correct). If I change the width to 720, then the height climbs to 544. Same idea… you increase the display width to match the anamorphic source, and the height climbs.
He did say “next episode”… I assume these are 4:3 TV shows.
Sometimes HB gets confused and choose a larger screen size. I’ve experienced it with a single BD,which gave something like 1088 in height or so (and it couldn’t play).
You can fix it a one of the first tabs, but it takes a few tries to get the right mixture of settings to keep the correct aspect ration … unfortunately I don’t remember the right settings ![]()
Cocovanna
You are 100% right it a A Blu Ray of the old Justice Leage series so that is why it is 4:3 aspect ratio. I just walked in the door from work and have to leave again in an hour so I will start a fresh copy of Handbrake and see what it initally comes up with. Unfortantly I can not check this page from work
too many fire walls and restrictions there. Thanks for all the great info and I will let you know how it turns out.
Roofing Guy: “If the BR has it stored anmorphic, the actual 4:3 “display size” should be 1440x1080 instead of 1920x1440”
What Blu-rays have you seen that are anamorphic? I believe that all Blu-rays are 16:9 and then you would set the inside picture area pixels. Then the pixel setting would be 1440x1080, which would be a 4:3 image on Blu-ray. An anamorphic 2.35 AR movie on Blu-ray would be about 1920x817. It’s similar to the old “letterbox” DVD’s before they started to make them anamorphic.
If you look at the BluRay Specs, the picture data can be
1920x1080 59.94i, 50i 16:9
1920x1080 24p, 23.976p 16:9
1440x1080 59.94i, 50i 16:9
1440x1080 24p, 23.976p 16:9
1280x720 59.94p, 50p 16:9
1280x720 24p, 23.976p 16:9
720x480 59.94i 4:3/16:9
720x576 50i 4:3/16:9
Picture data of 1440x1080 is anamorphic 16:9, by definition, unless it’s intended to be 4:3 material.
I’d actually meant “Unless the BR has it stored anamorphic…” instead of “If the BR has it stored anamorphic…”
Wiki’s take on it (for what that’s worth to you
“Unlike DVD, Blu-ray supports resolutions with Source Aspect Ratio (SAR) of 16:9, so widescreen video can be displayed non-anamorphically, with square pixels (a Pixel Aspect Ratio (PAR) of 1:1). Blu-ray also supports anamorphic wide-screen, both at the DVD-Video/D-1 resolutions of 720×480 (NTSC) and 720×576 (PAL), and at the higher resolution of 1440×1080 (SAR of 4:3, hence a PAR of 4:3 = 16:9 / 4:3 when used as anamorphic 16:9). See Blu-ray Disc: Technical specifications for details.”
But ya, sometimes Handbrake spews out the wrong picture size… especially after you’ve just encoded (or queued) something else with a different size or A/R. Usually when you get the picture size correct for the first encode, it will stay correct for the remaining encodes that session, if I remember correctly, when it’s a bunch of eps off the same disc. I’d guess that a 1920x1080 encode had been done previously, and Hanbrake got “stuck” on a width of 1920 for the 4:3 encodes.
RoofingGuy: I’m aware that they “could” make anamorphic Blu-rays, however, to my knowledge nobody (commercial movie Blu-rays) has made them. If they did, it would make up for the lost resolution when they make Blu-rays of Cinemascope movies that don’t use the full height of the 16:9 resolution of 1920x1080.![]()
I encoded the same file I have ben trying to get to play lastnight on the WD TV Life + still using the methoed in my first post then after it was finished I changed the container to MP4 and encoded it again. To my suprise it played perfectly then I encoded an episode of Hogan’s Heros and did the same one as a MKV and MP4 and the same thing happened. It played the MP4 with no problem keeping in mind that Hogan’s Heros is standard 640*480 and the Justice League was 1440*1080. I will pist the media info for your inspection
First the MKV file of Justice League
General
Unique ID : 76486591866648219074770547053657162682 (0x398AC8218E1B7F90B56DD5B865BD83BA)
Complete name : C:\Ripped DVD Files\Test01.mkv
Format : Matroska
File size : 538 MiB
Duration : 21mn 56s
Overall bit rate : 3 428 Kbps
Video
Format : AVC
Format profile : High@L4.0
Format settings, GOP : M=1, N=55
Duration : 21mn 56s
Bit rate : 2 719 Kbps
Width : 1 440 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.073
Stream size : 427 MiB (79%)
Writing library : x264 core 112
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : AC-3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 21mn 56s
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 100 MiB (19%)
And now the MP4 File of the same file keeping in mind that this one worked.
General
Complete name : C:\Ripped DVD Files\Test01.m4v
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 462 MiB
Duration : 21mn 56s
Overall bit rate : 2 947 Kbps
Encoded date : UTC 2011-05-12 06:10:01
Tagged date : UTC 2011-05-12 06:37:31
Writing application : HandBrake 0.9.5 2011010300
Video
Format : AVC
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 21mn 55s
Bit rate mode : Variable
Bit rate : 2 783 Kbps
Minimum frame rate : 19.173 fps
Maximum frame rate : 23.981 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.075
Stream size : 437 MiB (94%)
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 21mn 56s
Bit rate : 160 Kbps
Maximum bit rate : 195 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Stream size : 25.1 MiB (5%)
Tagged date : UTC 2011-05-12 06:37:30
And here is the standard 640*480 Episode
The MKV file that does not play
General
Unique ID : 65208762139637539387274602648506558767 (0x310EC03213BA0F349147B9A742A9692F)
Complete name : C:\Ripped DVD Files\HH1.mkv
Format : Matroska
File size : 374 MiB
Duration : 26mn 41s
Overall bit rate : 1 960 Kbps
Video
Format : AVC
Format profile : Main@L3.0
Duration : 26mn 41s
Width : 720 pixels
Height : 480 pixels
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=2 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=0 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 26mn 41s
The MP4 file that does play
General
Complete name : C:\Ripped DVD Files\HHMP4.m4v
Format : MPEG-4
Codec ID : mp42
File size : 452 MiB
Duration : 26mn 41s
Overall bit rate : 2 370 Kbps
Encoded date : UTC 2011-05-12 07:00:29
Tagged date : UTC 2011-05-12 07:11:07
Video
Format : AVC
Format profile : High@L3.0
Codec ID : avc1
Duration : 26mn 41s
Bit rate : 2 012 Kbps
Width : 720 pixels
Height : 480 pixels
Original display aspect ratio : 4:3
Frame rate : 23.951 fps
Minimum frame rate : 8.563 fps
Maximum frame rate : 65.123 fps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.243
Stream size : 384 MiB (85%)
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Audio #1
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 26mn 41s
Bit rate : 160 Kbps
Maximum bit rate : 310 Kbps
Stream size : 30.5 MiB (7%)
Audio #2
Format : AC-3
Codec ID : ac-3
Duration : 26mn 41s
Bit rate : 192 Kbps
Bit depth : 16 bits
Stream size : 36.6 MiB (8%)
