Can the same MyCloud be accessed remotely from both Mac and PC?
I am thinking of getting MyCloud.  If I set up MyCloud at my office (to access with PC), can I then remotely access it at home using a Mac?
yes i have a my cloud setup at my home and it runs great so far. WD supports both windows and Mac just make sure to download the correct software for the my cloud. When you get the my cloud it comes with a quick guide on how to set it up. It requires a wired connection to ether a router or an network switch. If you need additional help feel free to ask or contact WD support.
Thank you!  I will be accessing from both Mac and PC so wanted to double check :slight_smile:
Just bought My Cloud and haven’t opened the box yet.  Do I have to do anything special to set it up to be able to access from Windows, MAC, Droid or iPad?  Thanks
Well, yeah, you have to configure all the devices…   It’s all covered in the user’s manual.
