Cannot get the firmware to load
I have follwoed the directions, but I do not get any icon for upgrading firmware. I have hte files extraced to a new USB stick and they are the only things on there and still nothing. And when i hit “check for new update,” I get " the device fails to check for new firwmare…"
I reformatted the stick wtih fat32, but still no-go.
where should I go frm here?
Which firmware are you using?
1.0x.xx_V is for the LIve
1.0x.xx_B is for the Live Plus
I also cannot load the FWto my WD Live  from a USB key.
My USB key is FAT32 format.  I am wanting to go from 1.04.10V to 1.03.49V
Any suggestions?
Thanks!
SOLVED!
I was using the original version of the 1.03.49 FW.  You must use download the FW on this link:
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduse​r/std_adp.php?p_faqid=5800&p_created=1289519053&p…
I firgured it out. For some reason on Windows 7, it was just showing the three firmware file. I hooked up the sam SUB stick to my older windowsXP PC and it showed a folder and some other files,. I delted everything but thre three firmware file; set that back into my WD TV Lvie and the device recognized the upgrade.
thanks
