Can't connect my device to mycloud.com
If I try to sign-in to my account under ‘Cloud Access’ on my device this error pops up: ‘Something went wrong, please check that you have an active Internet connection and try again.’ The same happens if I try to create a new account or click ‘Invite’ for another user.
The device is definitely online, under the ‘Home’ tab ‘Cloud Access’ says ‘Connected’.
What could be the problem? Thanks.
I would suggest to collect the system logs and send to support for assistance.
Let me know the case number.
How to Collect My Cloud System Logs
Answer ID 18374
I am having the same issue today after upgrading to version 5.
Please share the solution.
This is on top of the indexing nightmare :frowning: that is taking ages.,
facing the same problem here! please help , im using the latest firmware 5.10.122 and everytime i try to sign into my cloud account i get this message "Something went wrong, please check that you have an active Internet connection and try again.’
@Nlar @Amshamali
Did you update your devices from OS 3 to OS 5 or from 5.09.115 to 5.10.122?
Please collect the system logs, open support cases, attach the logs to the case and let me know the case numbers.
Answer ID 18374
https://support-en.wd.com/app/supportoptions
My NAS got the update automatically , i checked the firmware version and it shows 5.10.122 , seems like this has to do with the update itself , also please note that i have the hardrive installed in Slot #1 if that makes a difference ?
Hello! I have this issue too, yesterday I contacted the WD support and the reference number is 211005-003438
Hello! I have this issue too. What do you mean that the reference number is 211005-003438? How can I find help with this number?
Hi @vagelis, I contacted the WD support, that number is the number they assigned to my request.
Thank you @nicola.cpz .
Hello everyone, just to inform you, I did not received any answer from the WD support but now I have just tried again to abilitate cloud access to my device and it worked. Maybe the WD team solved my problem remotely (I provided them the S/N of my device) or maybe it was just some temporary issue, who knows.
The first post on this was Feb 2021 and a year later I have this issue. WD tech support has been of little help.
