CIFS Speed maxed out at 100 Mbps on Gigabit switch
Unable to get SMB share speed to go above 100 Mbps no matter what settings I attempt to configure using the web interface for My Cloud EX4100… Device is connected to Gigabit switch, lights on adapter confirmed to be gigabit speeds (no amber), but transferring files maxes out at about 9 MB/s.
Any suggestions?
Enabled SSH, and checked /etc/samba/smb.conf which is listed below:
[ global ] netbios name = BKNAS02 server string = Offsite Backup Storage Device veto files = /:2eDS_Store/.bin/Network Trash Folder/.systemfile/lost+found/Nas_Prog/mirrored/uploaded/.wdmc/ workgroup = QEC security = ads passdb backend = smbpasswd realm = QEC.NU.CA password server = BKDC02.QEC.NU.CA template homedir = /home/winnt/%D/%U template shell = /bin/sh idmap uid = 10000-20000 idmap gid = 10000-20000 winbind cache time = 1 winbind use default domain = no winbind enum users = yes winbind enum groups = yes winbind separator = \\ nt acl support = yes local master = no os level = 0 preferred master = no max protocol = SMB3 max xmit = 131072 smb2 max read = 262144 smb2 max write = 262144 smb2 max trans = 262144 max log size = 10 log level = 0 socket options = IPTOS_LOWDELAY TCP_NODELAY SO_RCVBUF=2097152 SO_SNDBUF=2097152 delete veto files = yes unix charset = UTF8 encrypt passwords = yes map to guest = bad user null passwords = yes guest account = nobody dns proxy = no use mmap = yes use spnego = yes disable netbios = no strict allocate = yes csc policy = disable min receivefile size = 16k allocation roundup size = 0 create mask = 0777 directory mask = 0777 force create mode = 0777 force directory mode = 0777 use sendfile = yes smb passwd file = /etc/samba/smbpasswd disable spoolss = yes nt acl support = yes acl map full control = yes load printers = no unix extensions = no follow symlinks = yes wide links = yes printable = no
I’d recommend connecting your unit into a router or a different switch in order to confirm if this is a physical issue related to your NAS.
