Hi, I am using MyCloudEx2Ultra. One of the drives went faulty recently and I need to get a replacement disk. Both the faulty and good disks are of the model WD40EFRX. I couldn’t find reliable reseller who still sells internal disk WD Red WD40EFRX. Instead, I was told to another model WD Red Plus WD40EFZX is the newer version of WD40EFRX, and I should be able to use it as replacement. I checked the list of compatible drive but not able to see WD40EFZX listed.
Has anyone tried using WD40EFRX + WD40EFZX? Is WD40EFZX compatible with MyCloudHomeEx2Ultra?
I am considering a few options, with this as one of the options indeed. MyCloud interface is not that great - sometimes the files are not showing up on MyCloud app but they do exist when accessing the folder via file explorer as an example. Is Synology better from this aspect?
