I use a WD My Passport Pro (2To)
I have an issue when copying an SD Card (Sandisk SDHC1-32Gb) though it was fine 1 week ago.
I can hear the hdd is working as if it was copying something and the blue diods increase in number as the task is in progress but afterwards when I check with my laptop (USB 3) nothing new appears in the folder “Importing SD” except the previous imports I did several days before.
A help would highly be appreciated…
Thank you in advance
Were you able to confirm if the sync folder shows additional files or variations in size in order to confirm if files are being hidden?
Thank you Trancer,I appreciate your help !
I confirm that no additional folder was added nor files in any of the already present elements of the “imports sd cards” and nowhere else on the disk.
Could a reason be the reformat of the card in the camera before shooting again and wanting then to import it in the WD Passport Pro ?
If so it should already have happened many times but it didn’t.
Pol
I have good news, I spent some hours in trying to understand why I encounter these issues.
I read a lot about the issues or missunderstanding of a lot of users of the device and discovered the important and wide improvements of the new available uddate/upgrade of the firmware (v 1.02.24).
So I decided to update the firmware of my WDPP and …oooh miracle almost all of my questionnings are now solved !!
This is very important for me and I thought this information was also interesting as follow up or feed-back for you who are helping us, users of these HDD’s.
Thanks again for the time you spent for my question.
I wish you a good day/evening
Pol
