Data Volume 'DataVolume' doesn't exist!
hi,
I am using WDShareSpace version 1.2.2, and attached 4 hard disks of 1TB each connected using Type ‘Raid 5’
In storage->disk manager, status of all HDDs are Good.
But, in 'Volumes & RAID Management, Data Volume shows ‘Usage’ as ‘Unknown’, ‘Size’ as ‘Unknown’ and ‘Status’ as ‘Failed’.
The contents of ‘System Logs’ is:
11/06 15:25:05 WDShareSpace daemon.alert wixEvent[849]: Volume Status - Volume ‘DataVolume’ doesn’t exist.
11/06 15:03:24 WDShareSpace daemon.warn wixEvent[849]: iTunes Server - iTunes server cannot find the path to /Public/Shared Music. Please verify that the folder name has not been changed.
11/06 15:02:44 WDShareSpace daemon.info wixEvent[849]: Network IP Address - NIC 1 use static IP address 172.16.20.222
11/06 15:02:44 WDShareSpace daemon.info wixEvent[849]: System Startup - System startup.
11/06 15:02:44 WDShareSpace daemon.info wixEvent[849]: Network Link - NIC 1 link is up 1000 Mbps full duplex.
11/06 15:02:40 WDShareSpace daemon.warn wixEvent[849]: Network Link - NIC 1 link is down.
11/06 15:02:40 WDShareSpace daemon.info wixEvent[849]: HDD Status - HDD 1 is found.
11/06 15:02:38 WDShareSpace daemon.info wixEvent[849]: HDD Status - HDD 2 is found.
11/06 15:02:36 WDShareSpace daemon.info wixEvent[849]: HDD Status - HDD 3 is found.
11/06 15:02:31 WDShareSpace daemon.info wixEvent[849]: HDD Status - HDD 4 is found.
11/06 15:02:23 WDShareSpace syslog.info syslogd started: BusyBox v1.1.1
11/06 15:00:34 WDShareSpace syslog.info System log daemon exiting.
Please help me fix this issue.
Thanks in advance.
–uv.
Are you able to get all the data out of the drive and try to setup the RAID again?
Also, have you tried to reset the unit?
hi Morel,
Is there any solution other than resetting the unit.
thanks
uv.
Hi Morel,
Please tell how I can take the data out of the drive.
Thanks,
uv.
Hi  ubuntuv,
If you are not able to access the drive, please contact WD Support for direct assistance on your case.
WD Contact info:
http://support.wdc.com/country/index.asp?lang=en%22
