Hello
On my My Cloud 2TB dashboard, there is a critical notification named “Data volume failed to mount”.
The LED has turned red on the NAS.
I listed partitions by entering “df -H” :
WDMyCloud:/dev# df -HFilesystem Size Used Avail Use% Mounted onrootfs 2.1G 2.1G 0 100% //dev/root 2.1G 2.1G 0 100% /tmpfs 42M 3.7M 39M 9% /runtmpfs 42M 66k 42M 1% /run/locktmpfs 11M 0 11M 0% /devtmpfs 5.3M 0 5.3M 0% /run/shmtmpfs 105M 3.3M 102M 4% /tmp/dev/root 2.1G 2.1G 0 100% /var/log.hddramlog-tmpfs 21M 2.8M 19M 14% /var/log
4 4828MB 2000GB 1996GB primary
And if i try to reset by entering :
/usr/local/sbin/factoryRestore.sh noreformat
It gives me :
/usr/local/sbin/factoryRestore.sh: line 33: echo: write error: No space left on device
How can I clean the rootfs folder?
Sorry for my english, i’m french
