Displaying Moviesheets for TV episodes
I’m running Kudos V4 for both theme and movie sheets and love the way it works out for my movies. I’ve started trying to do some of the TV series I have on disc and I’m having issues getting the moviesheets to display at all for the TV series.
I changed the xml output for Thumbgen to the (newFW) selection for the WD as I understand that’s the correct one for TV series.
My file structure is this:
Tv Shows/The Big Bang Theory/Season 4/The Big Bang Theory S04E01.mkv
Tv Shows/The Big Bang Theory/Season 4/The Big Bang Theory S04E02.mkv…etc
Thumbgen finds the correct data for the episodes and builds the moviesheets just fine, but the SMP shows only the movie jacket (cover) file and no moviesheet or metadata for the episodes. If I change views, the SMP does have the metadata, but I prefer to view using the moviesheets since that’s what I’m used to doing for movies. I try to keep everything the same since not everyone who may have the remote is capable of pressing buttons to change views. When grandparents come watch the kids…it has to be easy :smiley:
What am I doing wrong that prevents the SMP from showing the moviesheets for TV episodes?
It’s a bug in latest firmware.
Thanks for the quick reply! I assume there’s no easy way to roll back to a previous firmware version until it’s corrected?
http://wdc.custhelp.com/app/answers/detail/a_id/5860/
Much appreciated! I rolled back t the previous F/W version and my moviesheets for TV episodes are all there. The naming didn’t pull in quite right but I’m guessing that’s a ThumbGen setting.
Thanks for the help!
