The built in media server on the My Book Live Duo does not work with MKV-files on Samsung All Share (DLNA)-tv’s, which is why I bought my new Live Duo.
Could you either address this hugh issue (which is a big issue on all you NAS-drives due to old Twonky-versions) or advice on how to install the newest version of Twonky ie. 6.0.39 on the My Book Live Duo?
Yes my TV is a Samsung UE46C7000 (with newest firmware). I also have WD MBWE White Light with 2TB and Twonky 6.039, which works perfectly streaming MKVs - even +35 GB sized files over wireless.
The MKV’s are of most general formats and encoding, x264, mp4, AVC with AC3 and DTS etc. I have hundreds of them in all formats, and none of the work. The error code is “Not supported file format”.
Yes, AVI-files work fine, and so do pictures.
If you google around, this is general problem with the MBWE, which demands a newer Twonky version of 6.03+, but since you use another media server on the duo, I am not sure what to do.
There is no need for transcoding since the tv perfectly accepts MKV’s (according to the specs and when using another media server such as Twonky +6), and since Twonky - Im sure - doest not transcode on the MBWE…
What media server is on the duo precently and can you help with installing another one such as Twonky?
