Downgrade MyCloudEX2Ultra
Hi guys, someone can help me downgrade my cloud ?
I Have EX2Ultra… I see some tutorials but dont know if work with my device…
I have OS5 but sleep mode no work with plex… Is very bad…
i want downgrade…
Thank you
Same with me.
I want downgrade from os5 to os3.
Os5 is a very bad update.
No sleep mode.
Very noisy hdd.
What you have done wd?
Nothing yet… Im searching about downgrade for solve all problems… You now fix?
At least try the newer OS5 firmware version if you have OS5 now as you wait for downgrade.
one new upgrade seemed to put index priority at a lower level and reduced the once a hour wake up a bit.
AND put a small fan on top of your unit to keep drives cooler while it does the indexing.
I always had to do that anyway with 0S3 during a raid re-build.
Downgrade method works great!! But the problem of sleep not solved… never go sleep… :frowning:
Someone can help me fix it ?
Use plex…
Thank you
your… works great!! You can help me about fix sleep issue ?
how can look ? I dont know… i open logs and appear clear… :confused: i’m using OS3
2.41.116 and disable all services…
yes, i check and are activated
Hi Steven,
i did the update to OS5 but i have only the mycloud mirror. So now, i have no access to my Cloud.
Do you have an idea to solve my problem and get back to OS3?
Timo
