I currently have the WD TV model 2014 Reference WDBPUF0000NBK (European PAL Version) and I want to know is what the HD DTS is supported? My amp decode DTS HD & Dolby TrueHD without problems.
in the audio settings HDMI is well described but only Dolby TrueHD & DTS. Is the “DTS” said includes DTS and DTS HD?
Thanks for you’re replys and sorry for my bad english i used a translator.
Yeah, that’s a decent cosmetic change… but WD still needs to fix the menu.
There’s still the issue for people that do have a DTS-capable receiver but NOT DTS-HD capable – DTS-HD won’t work at all for them; it won’t even pass the core.
They need to allow selecting DTS but UNselecting DTS-HD.
Since WD still can’t be bothered to add a simple black screensaver I’m using Joey’s modfied theme to replace the fidgety WD logo and also the Flixter ratings. If I would won’t this cosmetic change, could I install this mod over my already installed mod or would I have to merge the two mods into one zip and install this new mod from there?
Let me 1st say, i’m not doubting you … but can you explain this to me
I Have a 2014 WDTV Media Player & an old Teac DVR-301 … “Optical Audio” Connection to the WDTV
In WDTV Settings … selected Optical Pass-Through > Dolby Digital and DTS capable receiver
In both cases … i got sound through my Teac DVR-301 (led’s detected DD & DTS)
Now i know it isn’t true HD or MA … but the audio that came out (i’m not an audiophile,but) it did have “5.1 Channel Separation” (ran around the room putting my ear to each speaker)
So, i guess the question i’m asking is … does the DTS-HD (DTS-MA) on a Non Capable Receiver “No Sound” only effect the HDMI connection ?
Because, i don’t have a problem with my setup via Optical.
