We use the DX4000 for most of our customers, one of them is giving me a hardtime.
When i open up the dashboard, and i choose monitor.
Gathering information is shown, after a short while gathering completes: “Information not available”
No data is displayed in the upper right corner.
Eventvwr.exe is working
The problem is the NAS can’t detect if there is a defect HDD, or other health incidents. Also the mail notification is not working, the mail enable button is greyed out.
I tried the steps in the linked topic, changing the model to WDBLGT and restarting the “WD Enclosure provider” and reopening dashboard. no luck for me unfortunatly.
What i do notice are these events after restarting the WD Enclosure Provider
Service started successfully.
CreateNewAlertManager: Creating Alert Manager.
CreateNewAlertManager: Connecting Alert Manager.
Detected model number WDBLGT
Result from command ‘cscript.exe //NoLogo “C:\Program Files\Western Digital\WD Enclosure Provider\SyncTime.vbs”’ : 'Sending resync command to local computer
The command completed successfully.
Resync succeeded
In SetUEFIDate setting to 10-6-2015 17:53:20
Result from command ‘mountvol x: /s’ : ‘’
Result from command ‘mountvol x: /d’ : ‘’
Changed date in uefidate.nsh to : 6/10/2015
ClearPowerAlert: Alert Manager is not connected.
If you prefer i can make an export of the eventlog.
First of all i checked the date and time, those were correct and synced.
When i looked at the register value it had the full model name: WDBLGT0160KBK-42, i stopped the service, edited the value to WDBLGT and started the service. After this is I started the dashboard, no result.
Restarting the DX4000 clears the changes, same as you have been experiencing in the previous post.
I get this when I resart, then the rest is like yours
AlertMgrConnectionOpened: Alert Manager is now connected.
ClearPowerAlerts: Clearing all existing Power alerts.
I think the only answer you will get is to reinstall everything. I had this problem once (for the hard drive recognition only) and the solution was to reinstall from scratch. Pity this takes days
I agree 100% with you, the problem is that for most of the problems I had (similar to yours) the only final fix I was suggested (which of course in general worked but it required days of work without the NAS available and many hours spent as IT manager to follow the various steps) was to perform a clean re-install.
This happened for instance when the DX4000 did not automatically upgrade from RAID1 to RAID5 after having installed two additional disks even if this is one the key features reported in the DX4000 specifications.
