EX2 to EX2 Ultra
Is it possible without loss of data to take a drive from EX2 and put it into a EX2 Ultra and have it work without jumping through a lot of hoops like cloning?
Example: Take the 2nd drive (slot2) from the already running Raid1 - powered off when doing it of course - put in a new drive reserved for the Ultra - have it raid it when powered up. Then power down, put it in the new Ultra as drive 1 (slot 1) with the new Ultra drive 2 (slot 2) already installed, power it up and have it raid the drive?
I am pretty sure about the first step, as it should raid a new drive same size no problem in the old EX2.
Or should I put the new Ultra drive in drive 2 slot after it was raided by the old EX2 in slot 2?
Hi chetb,
It is important to know you can replace the drive but please make sure that the RAID configuration is same.
You can refer to the article below for more information.
