EX2 Ultra drive failure
Looking for some help on what to do…
I have received a number of critical error messages, including:
Drive SMART Failure
_ The drive 1 self-check failed. Contact WD Support._
_ Sunday, 31 December, 2017 11:25:06 AM Code:3_
_ Volume Degraded_
_ Volume 1 degraded. Please check status of drive by running Disk Test in Settings >> Utilities._
_ Sunday, 31 December, 2017 11:11:39 AM Code:208_
_ Drive Failed_
_ Drive failed in Bay 1. Replace the failed drive. Contact WD Support._
_ Sunday, 31 December, 2017 3:16:07 AM Code:201_
Under Storage > RAID, it states:
RAID Profile
_ RAID Health Degraded_
_ One or more RAID volumes are degraded._
_ RAID Volume Volume_1RAID 1 7.93 TB Degraded_
I’ve rebooted and haven’t done anything other than go to Settings > Utilities to run a Disk Test, as per the error messages above.
I’ve logged an enquiry to WD support and am awaiting a response.
Any advice on what to do in the meantime? I am terrified of losing data (but I assume since the other volume is ok, I’ll be safe)…but is there anything I can do?
Hello, kishlette,
http://support.wdc.com/support/case.aspx?lang=en
