Ex4100 Fan Fail
Need to replace enclosure due to Fan failure. Is there a procedure I can follow to make sure everything stays set the way It was originally.
Hello mhertich,
Well if the fan is failed of the enclosure please create a replacement of the drive if the drive is under warranty.
In order to check the warranty please check the given link.
Moreover, if the drive is under warranty please go thru the given link in order to create RMA.
