Hi everyone,
I have an external HDD with my media on it.
What would be the best way to connect it to my WDTV Live?
- Connect the HDD directly to the WDTV with the usb port and then just eject it and connect it to my computer to update/add new content, then connect it back to the WDTV.
- Connect the HDD to a USB switch and have one button go to WDTV and one go to PC, then just press the btton to switch it between the two.
- Connect the HDD to the WDTV with the usb port and then just add/update new content from the networked folder on my PC or by using the WD Link program.
Any ideas on what method would work best or how you all currently have it set up?
I have tried connecting it to my router and using it as a network storage, but it doesnt access the XML files to pull up the etra info about the media.
Any suggestions or ideas are greatly appeciated.
Thank you!
