Anyone know the faster way to move data from old Non-WD NAS to the EX4?
Moving via copy-paste from within Windows is painstakingly slow.
What I’m currently doing is open two Windows Explorer windows and on one navigate to the share on the old NAS and navigate to the share on EX4 on the second window. Then do a copy-paste from one Explorer window to the other but that is very slow.
If I can get to that sustained speed, I would be all set.
Out of curiosity, you have RAID 5 with 4 drives of 2TB WD red? or something else?
Just want to see if I’m missing anything in my config that would be the cause of the slower speeds.
Curently, I started a FTP folder copy job last night from EX4 that was still running as of today morning. The job tells me the time it started. Don’t know if it would show the end time once it finishes to ascertain the total runtime against the amount of data copied.
Do you know how how we can monitor the speed at which the ftp process is copying the data while it is running?
You can monitor the copy process by opening the UI in your browser, then clicking the arrow next to the Network Activity, CPU, etc on the Home screen. Than will show you the CPU usage, Network up and down speeds, etc.
You can also click on the either Network Activity or the small graph to see a larger graph of the Network up and down speed.
I tried onloading my ex4 from a external usb 3.0 raid0 setup. The transfer was still abysmally slow. I wonder if the ex4 does some type of crc checking of the incoming data.
