Hi, what theme do I have to install in order to get the same look as the one on Thumbgen default template?
When I create the xml and metathumb for a TV episode using Thumbgen it downloads all the fanart that series has on TVDB and it put it on a folder. The problem is that I have thousands of episodes all very organized, If I was to use thumbgen with them it would create thousands of folders, is there a way to insert fanart in the moviesheet without the need to create a folder, or if that isn’t possible how do I set thumbgen so that it doesn’t download all fanart, just the one I want?
