Firmware rollback on WDTVLive
I have tried searching this site to find out how to roll back firmware for my WDTVLive, but the search engine just plain **bleep**. I can not find any info on where the older firmware files are, and how to install them over top of the latest nonworking v1.03.49_V firmware.
Any help would be greatly appreciated.
P.S.
I can no longer access samba shares on my dlink DNS-323 NAS.
mp4 support is now broken. mp4 files encoded in h264 HD no longer have audio, even though the mp4 file shows a supported audio format.
Yeah.  Took me about 10 seconds.
http://www.wdc.com/wdtvlive_limitedpublicbetarelease/
Hi Tony;
I spent an hour searching without any luck. I did get thousands of hits on everything in my search phrase.
Thanks for the pointer, but does this file take you back to the 1.02.21 firmware v or the 1.03.43 v?
Since I can’t find anything else I will go ahead and try this. It can’t be any worse than what I have now.
Thanks again for the help.
The rollback link for 1.02.21 is below the Beta link, on the page Tony linked to.
You will need to edit the ver file (use notepad) to something higher than 1.03.49 (eg 1.03.50). This will fool the WDTV into accepting the downgrade. When it reboots with .21 firmware it will tell you that there is new firmware, ignore that or you will be going round in circles.
Obviuosly when connected to the net it will also keep prompting you about new firmware.
The package was already modified to report v1.04.21 and went in without a hitch.
Now I can connect to my NAS again and the audio for my mp4 files is now back.
The system reports firmware v1.02.21 installed.
Thank you all for your help and input.
Hi Tony;
As an after thought, what search terms did you use to find this link?
Thanks again for the quick help.
Hi Tony;
It is amazing how quickly I can become attached to a new technology device, and utterly lost when it quits working.
Hi Tony;
Thanks again to all those who posted on my problem.
rollback was a pice of cack as it define it self 1.04.* but it would not work if the installed version is more higher like 1.05 so anyone knows how to modify the version so it can always rollback my may be some one make it 1.20 or 5.*** i do not know coz thai *.21 is very stable version
how to do so fooling the version i will make a try then i will notify u
any one know to make update to put more codec or language
kmcewen wrote:
Hi Tony;
Here’s my GOOGLE-age:
“wdtv 1.02.21 rollback site:wdc.com -site:community.wdc.com”
You’ll never see an update to support new codecs.
The chip can only support what the chip was built to support.  You can’t add codecs to it like you can with software players.  If the chip wasn’t built to decode codec “X” then the player will never be able to play codec “X”.
Try this link
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_sid=XncNaCgk&p_faqid=5800&p_created=1289519053
BidaTV wrote:
Try this link
The link is better, and no need to edit any file first. Great work.
Okay, following the directions. Step five says “Select New Firmware Found”. But if one has already installed the new firmware (and are trying to rollback to a previous version) the “New Firmware Found” icon does not show up. One is already at the latest firmware. Why would the “Select New Firmware” icon show up. So what to do then?
Go to the solution that is posted in this thread:
Cannot Roll Back
Okay, thanks. Went there, tried it. It worked. Yeah! Thanks again. What worked and what is not in the directions that I found (at least that I could see) is that one has to edit the version file, specifically the firmware version number, to something higher than currently installed. I don’t see why that particular step is not included. But I figured it out with help from this board, so I am happy now. What specifically stopped working that made me rollback is that my .mkv files no longer played. I tried the “reset to factory” tip which didn’t work. But thanks again.
If you use the official rollback version this is already done for you. The problem is that the firmware versions are also available in other links, and since those were the original release of that version, the ‘version’ files have not been edited.
If you had downloaded the firmware from the WD link which was given in the tread
then there would have been no need to edit the version file. The rollback firmware on that page have already had their version numbers updated as they have been specifically created for rollback.
