Hello, im new in here and my english is a little bad but here it goes… The link for the firmware update isnt working for the WD TV HD Media Player (Gen 1), where can I found the files to update the player, anyone knows? is a website error?
My firmware is 1.01.02
WDTV Gen1 is Ancient … it will be 10 years old (a Decade) in 4 months time
WD don’t support it anymore or host the firmware
Here’s a gOOgle link … good luck
https://us.softpedia-secure-download.com/dl/ab7901d173bbbffd7d15f3b6adf418d5/5957b788/300086709/drivers/mediaplayer/WDTV_1_03_01.zip
The link dont work…
try this …
http://www.mediafire.com/file/2bscjm2kwbx812k/WDTV_1_03_01.zip
Many thanks, it worked, you the best.
THX. Gracias majo.
