Firmware: v04.00.01-623 - Device user ID missing. (400014)
Cloud Access
Cloud devices for “user000”…
New Unregistered Device >>> Code: – Expired:  1/1/1970  2:00 AM (1970??!?!)
Clicked “bin” to delete the expired code but I get same error “Device user ID missing. (400014)”.
Are you able to provide an image of what you are seeing? Are you on an Apple computer, Windows PC, etc.?
Posted by,
cat0w (USA)
http://community.wd.com/t5/WD-My-Cloud/Failed-to-delete-user-400049/m-p/775401/highlight/true#M19346
Windows 7 / x64
lucil76 wrote:
Cloud Access
It’s happen more and more
lucil76 wrote:
Windows 7 / x64
Exactly I have this problem
I have this same error. Multiple expired codes from 1970
Where is WD support??? I can’t believe they do such gorgeous hardware with such %&$·it! software!!!. Although I installed every firmware upgrade, this same issue, and the eternal DLNA database rescan time problems continue!!! I will install new clouds to customers in January, and unfortunately I will not buy WD anymore. Hope this helps others to think again when buying cloud hardware.
I am having the same problem as you…can’t get remote access on my device and have multiple expired devices  dating from 1969!!!  Is anyone from WD out there to support paying customers?!
