Recently I format my hard drive, but today I realised there are some documents that are very important for me. Now I am unable to get back my lost file. Is there any solution
First, you must stop using the drive. Any additional saves/writes can make recovery more difficult.
Next, you need to use a data recovery software to scan the drive, find recoverable components, then save them to another drive.
Depending on how many and how large the files are, you can try the tool from EASEUS (I’ve used this with some success). There is a free version here:
Note, it has a limit of 2 gb for recovery. More than that, you’ll need to pay for the Pro version.
If you’ve accidentally formatted your hard drive and lost important documents, don’t worry—there’s a solution. You can recover your lost files using BLR Data Recovery Tool. This powerful software is designed to retrieve data from formatted drives, including documents, images, and other critical files. Simply install the BLR Data Recovery Tool on your system, select the formatted drive, and let the software scan for recoverable data. Once the scan is complete, you can preview and restore your important documents with just a few clicks. It’s a quick and effective way to recover your lost files.
To recover important documents after formatting your hard drive, first, stop using the drive to prevent overwriting data. Next, use the best Stellar windows data recovery software Open the software, select the types of files you want to recover, and choose the formatted drive to scan. After scanning, preview the recoverable files and save them to a different location. Acting quickly will improve your chances of retrieving your lost files.
To retrieve critical documents after formatting your hard drive, immediately stop using the drive to avoid overwriting data. Then, utilize Stellar Windows Data Recovery Software. Launch the software, specify the file types you wish to recover, and select the formatted drive for scanning. Once the scan is complete, preview the recoverable files and save them to a different storage location. Acting promptly enhances the likelihood of successfully recovering your lost files.
