My G-Drive 2TB USB3 with Firewire backup is less than 1 year old
0G02529
I use this for time machine backups on my Mac Pro Server (Mid 2010)
This is one of two similar drives in rotation
OS X El Captan 10.11.4
The drive has been giving me trouble for months.
I decided to re-format the drive and do a new, clean backup.
The initial backup ran perfectly.
Total backup is 982GB.
After consulting with a G-Technologies agent, I was encouraged to update the firmware on this external drive.
I downloaded G-Technology_Firmware_Update_Utility0614
Installed and ran this on our Mac Pro with only the problematic G-Drive connected.
I restarted the computer and the drive.
Time Machine ran successfully the first time. But it failed on the subsequent attempt (one hour later)
I cannot eject the G-Drive because one or more application is using it.
I ran disk utilities/first aid on the G-Drive.
Process failed with this error message:
“Updating boot support partitions for the volume as required.
Unable to unmount volume for repair.
Operation failed…”
What are my next steps?
Shall I begin a return process and acquire an RMA?
Thanks in advance.
