Ajenti is a pretty advanced Remote Administration tool.
If you don’t know what your doing, leave this thread now!
This type of modification is done at your own risk and will void the warranty of the drive
Pretty basic install and runs ok on the MyCloud minus some Ajenti plugin errors when the Dashboard loads
What is Ajenti http://ajenti.org/
Ajenti includes dozens of pre-made plugins that let you configure both your OS and server software. List of supported software includes Apache, BIND9, Cron, CTDB, DHCPD, NFSD, Iptables, Munin, MySQL, Netatalk, NGINX, PostgreSQL, Samba, lm-sensors, Squid 3, Supervisor.
Fast and responsive interface, low memory footprint and handy tools like file manager, terminal and code editor - everything a happy sysadmin needs.
On with the install which is mostly a copy and paste from the Ajenti website
Download the Ajenti key
wget http://repo.ajenti.org/debian/key -O- | apt-key add -
Backup your sources.list file
cp /etc/apt/sources.list /etc/apt/sources.list.bak
Add the Ajenti repo
echo "deb http://repo.ajenti.org/debian main main debian" >> /etc/apt/sources.list
Install Ajenti (When asked if you want to continue type y and hit enter
apt-get update && apt-get install ajenti
Restart Ajenti
service ajenti restart
Move back your original sources.list
mv -f /etc/apt/sources.list.bak /etc/apt/sources.list
You can now log into Ajenti using a secure https connection…Your browser may ask you to add an exception
https:// your MyCloud IP or Network Name :8000
Username: root
Password: admin
When the dashboard first loads you will be presented with this error message, just click the continue button and all is well
[Errno 2] No such file or directory
Traceback (most recent call last):
  File "/usr/lib/pymodules/python2.7/ajenti/plugins/main/main.py", line 251, in init
    cat = cls.new(self.ui)
  File "/usr/lib/pymodules/python2.7/ajenti/api/ __init__.py", line 88, in new
    return context.instantiate(cls, *args, **kwargs)
  File "/usr/lib/pymodules/python2.7/ajenti/plugins/ __init__.py", line 177, in instantiate
    init(instance)
  File "/usr/lib/pymodules/python2.7/ajenti/plugins/samba/main.py", line 58, in init
    self.monitor = SambaMonitor()
  File "/usr/lib/pymodules/python2.7/ajenti/plugins/samba/status.py", line 7, in __init__
    self.refresh()
  File "/usr/lib/pymodules/python2.7/ajenti/plugins/samba/status.py", line 12, in refresh
    ll = subprocess.check_output(['smbstatus', '-p']).splitlines()
  File "/usr/lib/python2.7/subprocess.py", line 537, in check_output
    process = Popen(stdout=PIPE, *popenargs, **kwargs)
  File "/usr/lib/pymodules/python2.7/ajenti/compat.py", line 25, in Popen
    *args, **kwargs)
  File "/usr/lib/python2.7/subprocess.py", line 679, in __init__
    errread, errwrite)
  File "/usr/lib/python2.7/subprocess.py", line 1259, in _execute_child
    raise child_exception
OSError: [Errno 2] No such file or directory
If you get connection lost errors while loading a few of the pages, don’t worry the page is still loading
REMOVAL (This was a pain as there were no clear instructions but this will get it done)
apt-get autoremove ajenti
rm -rf /etc/ajenti
rm -rf /var/lib/ajenti
dpkg --purge ajenti
apt-get clean
Ajenti is now removed from your MyCloud
Screenshot
