I have had a WD Element external hard drive. It is 1Tb capacity.
It is old - bought October 2009
Use mainly for Genie Timeline Pro backup.
For some reason it stopped working. I unplugged it, let it cool down then plugged it in again. When it restarted it now only has a capacity of 31.9 Gb and there is nothing on it?
What has happened? Is the rest of the drive retrievable?
Luckily there is nothing vital on it.
主题: [WD Community] [WD External Drives/External Drives for PC] Hard Driveshowing up incorrect capacity
Dublin17
October 8
Hi Hinata
Yes I solved it.
I went into disc management, deleted the volumes and created a new
partition (for the whole disc)
Bets of luck it works for you
Dublin 17
Visit Topic or reply to this email to respond.
In Reply To
Hinata
October 2
Sorry to bother you. But I have met the same thing as u. Did u solve it? If you have solved it, could you tell me how did u do so? Thanks!!!
