Fixed my Cloud by using virgin 2tb image from this thred: http://community.wd.com/t5/WD-My-Cloud/How-to-unbrick-a-totally-dead-My-Cloud/td-p/651195/page/6
Be warned, most probably it is not in a healthy state although the Dashboard says so.
PS: Got PM which confirmed my assumption.
Hmm, is there a way to fix it?
Ask Bill_S for a correct virgin image?
I run utilites->full test, and now I got:
WDMyCloud:~# cat /proc/mdstat
Personalities : [raid1]
md1 : active raid1 sda2[1] sda1[0]
     1999808 blocks [2/2] [UU]
unused devices:
I guess this meand RAID is OK now?
unused devices:
This means that the raid is no longer degraded, but on fully healthy boxes it should be on md0
Who can help ?
I connected my drive to a Linux system to overwrite the two raid partitions but i see no option to chose ârestore disk imageâ.
I see the two raid partitions in âDiskâ but not been able to overwrite it.
Could it be possible that these partitions are write protected ?Â
I followed the guide from Sammarbella on page 1.
My cloud have the yellow blinking led and iâm not been able to do the 4 or 40 sec. reset.
I have the file roofs.img to write over the 2 raid partitions and iâm in Ubuntu utility named Disks.
But i see no option to write it over the partitions on the My Cloud.
Sammarbella wrote:
"Open disk util in ubuntu (disk, disks, gnome-disks several namesâŠjust alt-f2 âgnome-disks) select the first raid partition in MyCloud HDD , click on the gears icon (the one in the middle of the util screen)â
âclick on âRestore Disk Imageâ, browse using the combobox and select rootfs.img.â
I see no gears icon and have no option to choose for âRestore Disk Imageâ
Solved on the way JRman described.
The only thing is that he forgot to say that you must type âsudoâ before the command to overwrite the raid.
Otherwise you get the error  permission denied :smiley:
I am read a few branches on the forum and did throught manual. Nas is works fine, but on the old frimeware.I try to update it. the process of downloading, then install and reboot after the firmware is old.
I made a bash script that redo a fresh virgin my cloud system with any disk, or to an image file. From scratch. See this thread.
Hi all,
I have the 4TB version. Initially I was having issue that I canât access the webUI with error access denied. I have no other choice but to do the 4secs reset. After this the issue is still there and then I tried the 40secs reset. This made me lose the SSH access and I still got the error access denied from the webUI.
The question is how long does it takes for the device to initialize at first boot after overwriting both raid mount with the rootfs.img?
Nazar78 wrote:
Hi all,
I got it fixed, the extracted rootfs image was corrupted somehow when transferred to a VM as I canât loop mount the image. Thanks to this useful thread⊠Did a few tweaks, 50-70Mb/s up and 60-80Mb/s down.
Just to share how I restored the rootfs.img below. If you do this, be prepared to void the warranty. For my case it was already voided on day one due to root
Details with resized photos :
1) Remove the harddisk:
Place up right on a flat surface with the device rear facing you, slide in two 15cm rulers into both rear openings (starting from the top curves all the way till the bottom end). Alternatively you can use two credit cards but you need to align them near the inner/outter catch clips. Apply light pressure at the top of the device towards the flat surface while you gently tap on the two rulers inwards. The plastic catch clips should easily pop off after a few taps. To remove the cover, slide it out towards the front of the device along the slide guide. After sliding the harddisk out, remove the three obvious securing screws from the PCB then separate the PCB from the harddisk via its sata connector. Be extra careful not to damage the âprotrudingâ LED light.
2) Three options to mount the harddisk:
a) Mount the WD Red harddisk to any PC extra sata port and plug in the sata power cable. Hotplug would be great.
b) Get a SATA-to-USB cable/adapter. Never tried this but I think you will need a way to power up the WD Red harddisk.
- c) Get an External Harddisk enclosure. Doesn't matter USB2/3/eSata as long as it supports Sata harddisks.
3) Restore the two 2GB Raid partitions with rootfs.img extracted from the official firmware:
If you're using Linux Distro, I'll assume you'll know the rest of the recovery steps. But for Windows, best is to download any LiveCD/gparted ISO or Linux Distro ISO and run them via VM for Windows. This can be easily achieved even without installing the distro, use the "Try" method. I shall not elaborate on how to run/use a VM, you can find these online especially on how to load the USB filters. For my case Lubuntu via Virtualbox's USB filter to load my External Harddisk enclosure USB interface. For LiveCD use gparted app, for any other distro I would recommend DISKS app. Advanced users may use "dd" dump. Transfer the rootfs.img to your distro working area such as ~/Desktop via SMB or SFTP. Select your harddisk and locate the two 2GB Raid partitions and choose the rootfs.img to dump into these two partitions. With DISKS app or forked "dd", you can dump the two partitions at once. You can choose to backup these two partitions prior overwriting but I think it's unnecessary due to it's already corrupted but unless you need to retrieve back any custom modifications to the rootfs.
4) Finally:
Once you have restored the two 2GB Raid partitions, assemble back the device and power up. The public shares should appear within 2-3mins and you can proceed with the My Cloud's Quick Restore if necessary. If you still can't still the shares, check if the original rootfs.img is not corrupted. You should be able to loop mount this rootfs.img on the Linux distro and browse its contents. Else your partition table is really corrupted. Read up more on this thread for the solution provided.
That *almost* worked the magic.
I took the dang thing apart and connected the drive to my PC.
Installed Ubuntu-Gnome on a USB drive and booted PC with it.
I did the firmware restore thing that sammarbella wrote.
reassembled the dang thing and, walla~ blue LED. And I can even connect it.
Trouble is, it somehow halts at user name screen where I input my first and last name and email address, but never a password. When I try to reconnect. There is a user name in my first name and password is nothing I can guess. Tried password recovery through WD site, but the site says it canât connect. SSH connection isnât obviously possible.
I did the whole process again by taking it apare again (dang, Iâm getting good at it) and the same thing.
What should I do? Perhaps I will try with a former firmware, if I can find it. If that doesnât work, I will try dumping mycloud image from some funny Chinese site (that I donât trust) on the whole drive. If that doesnât work, I will prolly throw the dang thing outside of the window.
Hello all! I am another unlucky owner of a my cloud 2 TB with white led issue.
As reseting the device did not work, i might be forced to open it . But first i have a few questions:
1.If i do it this way my data is lost?
2.Where do I get a 2TB image so i can restore it?
3.After I do restore the image , upgrading to the latest FW 4.00.00-607 Â will make the soft like âout of the boxâ? Meaning no errors?
4.I have waranty, so if i send it in service would they replace the unit? Can they see if i had SSH enabled and void the waranty? I did not do anything over SSH but left it enabled for situations like this (but useless).
Instruction :Â https://drive.google.com/file/d/0B_6OlQ_H0PxVejVic2ZubXBfbHM/edit?usp=sharing
Backup image :Â https://drive.google.com/file/d/0B_6OlQ_H0PxVSWl6ZURLMGJKT1U/edit?usp=sharing
- If you use this instruction - no.
- No need to get full-size image. Just RootFS, kernel and config. (See header)
- See this:Â http://community.wd.com/t5/WD-My-Cloud/ALL-OF-MY-Cloud-Problems-Solved/td-p/776603
- Yes. Sometime WD replace âdeadâ cloud to another or repair hem in few days.
Thanks for your quick reply .
Will do it this way
Can I extract the rootfs from oficial v4 firmware and write it instead?
dpkg -x firmware.deb
tar xvf firmware.deb
Or any GUI arhiver.
Also you need Kernel from v4 (Important!)
Thank you for your assistance, you saved my drive.
I managed to get it up and running last night, backed up everything , restored the FW and upgraded to V4 clean as you sugested. So far itâs working flawleslyâŠspeeds increased , better UI response âŠand fixed my problem with the subtitles over dlna.
Dear sammarbella, I tried to restore rootfs.img into my both raid partition but without any results. I have an error that device is busy. When I open disks in open susy I saw WDMC disk with all partition and raid matrix. First what I tried to do to make backup of both raid partitions but also error device is busy, When I go to raid matrix there are connected both raid partition. I can make backup and I can also restore img file on raid matrix.
Can You tell me what I should do to restore both raid partitions.
I red most of the themes at this forum and I donât know what to do.
I have problem with blinking white led. I lost some date probably after firmware update. I bricked my WDMC and restored date with r-linux. When I assembled WDMC and tern power on I have white led. I tried put 40 sec. reset button, no results. I am angry of this but I want to make my WDMC live. Thanks for your help.
