How to use plex with local connection
Hello, now that WD has allowed the access via a local connexion, I can use my cloud as a smb server with vlc on my android tv. So that’s a fine temporary solution.
Do you now if there is a way to make plex work again on local connexion? Is there a way to set it up. I’m affraid that the day wd stop really supporting the mycloudhome, i won’t be able to fully use it as intended.
Thanks for the help
Hi @mx5kev,
Have you opened a Support Case? If not opened, for more information, please contact the WD Technical Support team for the best assistance and troubleshooting:
https://support-en.wd.com/app/ask
