Info on movies / TV. Shows
Hi everyone !
just wold like to know if their is ,and ever will be a way to cheek the INFO on a movie and or tv show through WD.
If not , it would be a great feature for WD, I do know that their others multimedia centers that has this feature but ■■■■ on the others what i understand !
thank you
pandabear6666
If you would like to check the info you can use GET INFO
there is a link on the software in the user manual page 144
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705043.pdf
