I am really like this device but did not compatible to WDTV live
Hi pocketeer, welcome to the forum!
WD don’t seem to have a schedule for adding support for new wifi devices.
Also, they don’t seem to have any mechanism for requesting specific hardware be tested / added (nor is it likely they could get it into a firmware within the next several months).
If you need to set up your wireless network now, your only choice is to look at the current supported hardware list and choose a device from there.
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=3805
If you’re willing to make a request to WD, try posting a thread in the Ideas Lab (link is top centre of the page).
Title it: “Support for Belkin F7D4101 / Broadcom BCM4323 Chipset”
The main issue is chipset support. There are a number of unlisted brands / models that do actually work because the Live supports the same chipset. You could argue that supporting that specific chipset will add a range of support for other devices.
But there’s no guarantee they will action your request. Doesn’t cost you anything to try though. ;)
Also, check out section 3C of the FAQ for other options.
Thank you I have posted hope they would reply yes or no
Thank you very useful information.May I go to shop and see what I can have to make it up
